ahammed akkif
I use my Expedition front signal lamp as DRL with forscan. The turning lamp does not work when it is switched on as DRL, how to make both work together
Actually, there is a FORScan code to do it on Gen4 Expeditions. I did it a while ago, but, since mine had a dead passenger DRL when purchased and the cost was $1200 to replace, which the dealer paid, I decided to not even use them except when my headlights are on at night. So I reversed it.In order to do that, you need to wire in a relay or a flasher. DRL lights are always on, so you can't see blinking because it is still being powered on the whole time. Need to interrupt drl signal to see blinking. I am having same issue upfitting the drl circuit to strobe with a wig-wag for emergency response lights. Find turn signal wire and use it as the switch wire on your relay. Google something like "how to wire wig-wags on headlights or drl"
