Electrical issue
Butch Smith
Atlanta,Georgia
2013 145000 miles , running great, serviced regularly. Low fuel level warning and tire pressure and check engine light started coming on today. Full gas and tires. Could the battery be going bad? When I turned it off it would reset for a little while.
Fastcar
Army
FL
Have your charging system tested.
sandbuster
Titusville FL
Batteries are capable raising havoc in your electrical systems even when the battery may indicate 12+ volts. As the other person stated (and you did) always load test the battery if in any doubt at all. Glad you got it resolved.
B
Butch Smith
Atlanta,Georgia
Turns out it was the instrument cluster going bad. Now trying to get that replaced which is a problem because they have to be rebuilt.
