Engine dropping to idle at speed
Hbar
Beaumont TX
My '15 Expedition has begun randomly dropping to an idle at any speed during various levels of acceleration. The throttle becomes totally useless. I can turn the engine off and back on and it will run fine. The first time it happened, the dealer replaced the throttle body. I recently took it in and the dealer claims they can't find the issue without seeing it happen. Ideas?
Timo2824
Wichita
Your throttle body will need replaced, it's loosing it's position and the safety is to return to idle position.
Andy Rubalcaba
Riverside, CA
I could be wrong, but since they replaced the throttle body already then my next thought would be to replace the crankshaft position sensor? give that a look.
i don't think it would be idle control valve, i've had plenty of that issue on my old land rover, which acts a bit different ( high revs or nearly stalling out ).
Goofy173
Ky
Also this is accelerate by wire. If it loses connection from the gas pedal to the computer, it will drop to idle. First reset the connector at the gas pedal. I had this happen when I added an accelerator controller and didn't get the connector completely snapped in and it popped off.
YMRacing
Champaign, IL USA
I'm on my third throttle body. Yah, they told me they couldn't find any codes because they cleared each time I shut it off and restarted it. I hooked up my OBDII reader and left it in. I then had the codes each time it happened. I have a 2017 with 35k. All have been replaced under warranty, first in WI, second in IL, 3rd in TX. I now carry an extra one with me.
