exterior temp incorrect
jman
frisco tx
Anyone had a problem with the exterior temp reading incorrect temps? It was 91* out and temp read 71, one time it went down to 58* and then back to correct temp. ??
B
bedrck46
check the sensor for any obstruction or dirt covering the sensor
Check sensor connector for any signs of corrosion
Key in OFF position.
Disconnect: Ambient Temperature Sensor C132.
Measure the resistance between the ambient temperature sensor C132 terminals.
Is the resistance within the specified values for these temperature ranges:
10-20°C (50-68°F), 37,000-58,000 ohms;
20-30°C (68-86°F), 24,000-37,000 ohms;
30-40°C (86-104°F), 16,000-24,000 ohms?
if not in range then you may want to install a new sensor
