jedross86
Hi All,
I have a 2019 Platinum Expedition Max. The engine was replaced about 5k miles ago. Currently at 67k miles, family car, no towing.
When I got my car back from the dealership with the new motor I started noticing the coolant temps pop up on my gauge cluster when highway driving and going up inclines, which I had not once seen before with the old motor. I read into this a bit (and even posted here) and thought it might just be due to break in period. After 1k miles I had the oil changed, the coolant checked, and this kept happening. I took it back to Ford and they did some diagnostics and said the engine temps were within normal range. They did give me a print out but my wife threw it out
. This today is still happening with highway driving and going up an incline and I'm really starting to worry that I'm heavily taxing this new motor and that I won't get much life out of it if this continues.
Some observations when this happens - like I said generally on an incline/hill and going over 60mph. Most of the time I actually don't see the temps spike until I crest the hill but there are times they do creep up while going up the grade. It usually occurs only for a few seconds... I'll get a reading at 232F, might creep up to 234 and then after 15 seconds or so I'm back to not seeing a temp (so under 225 I believe). I also have noticed my engine fans are running much more frequently than I recall with my old motor.
What would you all do if you were me? Any thoughts on what the problem could be (faulty thermostat? someone told me maybe a water pump problem?)?
Any help is much appreciated.
Thanks!
Justin
Thanks!
Justin
