the ends of the brake pads (they are u shaped, at least for 98) also slide along where they mount to the brackets,
eitherway, lube area points also
ditto on this part (feel the front disc rotor (carefully!))) checking for heat, if they are dragging, they can get too hot to even touch
i had a caliper that would stick when braking hard, when it did, i would get a humming noise,
when you say "squeaking", do you mean just under braking? or constant? under braking doesn't necessarily indicate/mean dragging or sticking
