If anyone is going to do the front brakes on your 1997 and think your just going to get the rotors turned, have fun. The rotors DON'T come off easy. I ended up replacing the rotors. When they were designed the factory did'nt give the rotors very much of a gap between the hub and rotor and over time dirt, rust etc. gets in and seizes the rotors to the hubs. Without using a torch, I got them off but I had to use a sledge hammer. Whatever you do if you get the old off or you just buy new, make sure you invest in a tube of anti-seize and smear it around the hub were the rotor fits and it might help save problems in the future. Has anyone else had this expierence or was it just me????
