jpav
Got a 2006 Limited and the previous owner pointed out the front right seat doesn't go up/down or forward/back. The tilt back and lumbar work fine.
She didn't know why, but her boyfriend had changed the switch to the driver side. I assume maybe it wasn't working, and was an easy swap to check.
Are the switches in fact universal?
Other than swap parts back again to check, is there an easy way to confirm it is the switch? Or can it be torn apart for repair?
I did notice the plastic cover on the broken seat has one of the tabs broken off that holds it, so it doesn't sit tight. I may do a junkyard run if these parts are more universal so I could find a good used one.
Thanks,
Josh
Thanks,
Josh
