Aspen03
Not Expedition related. If not allowed feel free to delete.
2007 Grand Prix GT for sale. 185646mi.
The Good:
I'll snap other pics tomorrow when the weather is nice. Had these on hand...
The Good:
- Stealth Gray Metallic
- Supercharged Series 3 3800 motor 260hp/280tq. Stock drivetrain, no mods.
- Black leather Interior
- Heated front seats, power driver seat
- Sunroof
- Power Mirrors
- Factory audio system with no issues
- 5 button driver info center you can actually change the radio of you wanted.
- New brakes (pads, rotors, calipers)
- New Timken wheel bearings on all 4 corners. Got NOS before change in manufacturing, they're the good ones. Receipts for above parts available.
- Tire rod ends replaced and 1 rear trailing arm
- All power/electric equipment works. Seats, sunroof, radio, etc. Ice cold AC, toasty heat.
- Interior is solid. I steam cleaned the entire thing including vents and interior glass, dressed it, cleaned carpets, and did an Ozone shock treatment. Aside from some wear on a few radio buttons it's in amazing shape for the age/miles. It's always been a non smoker vehicle as well. No tears in the seats, average wear on the bolsters. There is one spot of grease on the sunroof shade that I did while cleaning it up. Unknowingly got edge of finger in sunroof track and touched the damn panel. I'm afraid to scrub because it'll likely just smear.
- I purchased this vehicle from a co worker 3 years ago to turn into a toy for the track....drag race/autocross or whatever. It never happened and sat in my father in laws climate controlled garage until a couple months ago. Regularly started, brought up to temp, moved around the property to keep things from sitting idle too long.
- I found it for said co worker in 2015 for him to use as a commuter after he got transferred across the city. He purchased it from the original owner. Based on condition once I saw it and the records he had I believe it though he didnt bother to get a carfax. Unfortunately him being 20 and probably figured he'd never sell it he didnt keep anything...
- It was in a low speed collision by him, he ate the hitch of a truck. No bags deployed. Bumper, hood, hood latch took the brunt of it. Front bumper is a certifit replacement, primed black. Hood is a factory hood in Galaxy Silver. It has clear issues on sides of hood and quarter panels and isnt too bad looking color wise. Grill inserts are blue because I had them lying around already. I wasnt after looks so i didnt care. If you wanted a color matched vehicle the parts are readily available on car-part.com A0 rated for about $300 with a0 rating, likely half that at a u pull it near you.
- It needs rear tires now though I have a pair that could be mounted for safe travels home and an alignment due to work that was done, fronts are about 85%. Throw new ones up front, move existing to rear and you'll be balanced out when it comes time to rotate. 2 wheels dont have TPMS sensors and it let's you know...
- It has the service abs/traction control message in info center. Typically bad abs sensors in the hub cause it but them being new and of good quality I dont know what the issue is as there is no specific code being thrown. Drives fine otherwise.
- P0449 is active and P0033 is showing as a pending code. 449 is most likely the canister vent valve by the tank they're a common failure point (havent had it in the air to confirm) and the 0033 is the control solenoid for the boost bypass valve 9/10 times it's right above front valve cover. These are about $80 between them and doable in about an hour or so if you're handy. I have enough going on vehicles wise and with work I'm ready for it to have a new home and priced accordingly.
