Fuel filter location , keyless code
bruno
Hungary
Hi!
I'm Bruno from Hungary, i have a 2009 Ford Expedition 4x4 Eddie Bauer, and i have 2 question:
- where to find the fuel filter on my car?
- i have keyless system, I do not know the code, where do I find the car to the factory code?
Thank you for answer!!!
Bedrck47
Elizebethtown, PA
for keyless code
Keyless Entry Keypad
The keyless entry keypad, located on the exterior of the driver door, provides a method for the customer to access the vehicle without a key or RKE transmitter. The keyless entry keypad feature:
Locks all doors
Unlocks only the driver door
Unlocks all doors
Programs/erases the customer keypad code
Enables/disables auto-locking
Enables/disables auto-unlocking
Releases the liftgate glass
The keyless entry keypad feature operates independently of ignition status, vehicle speed, or transmission position. When a keypad button is pressed, the keypad buttons illuminate to provide better visibility. If 7/8 and 9/0 are pressed or 5 seconds have elapsed since the last button press, the illumination is turned off.
Each vehicle equipped with a keyless entry keypad is programmed with a 5-digit entry code. This code is provided to the customer on a wallet card in the Owner's Literature package. In addition, this code is available through a scan tool. When entering codes, each digit must be entered within 5 seconds of the previous button press.
also read your owners manual
catmandu
Sierra Nevada
Fuel filter:
If you have a 28 gallon tank, the filter is part of the fuel pump module inside the fuel tank. If you have a 35 gallon tank, the filter is on the front edge on the outside of the fuel tank.
No members online now.
Landsbutter
