Contender54
The gear indicator disappeared from the cluster of our 2020 Limited after we had the transmission replaced.
Has anyone else experienced this?
Is it an easy fix?
Is it an easy fix?
When you are in Drive, press the "Plus" button below the shifter.
It should then pop up.
It worked. Thank you!When you are in Drive, press the "Plus" button below the shifter.
