Heat
Ford78david
N.c
I have checked fluid blend door hose temp coming out of heater core but the heat sucks in my 99 expedtion takes forever to get warm but then some days it works great. Have to keep fan on low to get heat if you turn fan up the heat turns cooler.. same for the back of expedition. Any ideas it has the fancy push button temp controls. Thanks
Trainmaster
Old School Member
Rockaway Beach, NY
With the age of your truck, it's possible that your heater core is clogged. You can try flushing it, or if that doesn't work it would require replacement. It sits behind the dash and the dash must be removed for access. It's perhaps a four hour job if you do your homework.
It's also possible that there's an air bubble in the coolant lines or a head gasket problem that's permitting the coolant level to leak down between driving cycles. Check the coolant level and the condition of the coolant system. Has the anti-freeze been changed regularly? If so, it's less likely that the heater core is clogged.
You can try reverse-flushing the core, and that should give you some relief, though it may be short-lived and you may have to replace it next year.
I've been through this on a 2000. Not a bad job if you watch the videos on You tube, and use the proper tools. Don't cheap out. Use a Motorcraft replacement or you'll be doing the job twice. The cost of having someone do it here in New York is outrageous.
Ford78david
Ford78david
N.c
Thanks both hoses are hot after a drive. Idk some times it blows out hot air great. Been raing all week her in n.c hope to mess with it this week. Tks for your advice
Trainmaster
Old School Member
Rockaway Beach, NY
The hoses should heat as soon as the temperature gauge starts to rise. If not, check your thermostat. Maybe it's sticking? And of course the water level.
1955moose
I think Trainmaster nailed it. One last thing, make sure carpet isn't binding down there. From your description it sounds pretty much like flow. Heater core or thermostat. Your SUV is going on 20 years, a lot of coolant and sediment build up if not flushed out. Try the flush, but count on a front core replace.
hammerg26
North Georgia
Not to beat a dead horse and I am still perplexed.
Hoses are hot.
Hot air blowing out, and to about 40 degrees, it heats up. Below that, the heat barely works.
Is that still a flow issue?
Thankfully I live in North GA, so it is not that cold. And I do drive to NC for skiing and heat would be nice there.
1955moose
If both hoses are hot, sounds more like a mechanical thing. Check and see if blender doors are opening/closing proper. Make sure carpet isn't binding something in there. Seen that here. The heater control valve is another check. If it's vacuum operated, make sure diaphragm is good and holding.
Trainmaster
Old School Member
Rockaway Beach, NY
Imagine this.
The heater core consists of a clump of two dozen tubes through which the hot water flows. They are all connected in parallel, so the water flow is split between the 24 tubes. Down 12 and up another 12.
Now imagine that all but four are clogged. You'll still get flow through those four, so both the input hose and the output hose will be hot. Mildly cool air is being blown across the tubes, and those five hot tubes give up some heat to the air. Since the water volume flow through four tubes is less than the designed flow through two dozen tubes, the velocity of the water flow is increased. Thus the water cannot give up all its heat to the airflow, and it exits the heater core at a higher temperature than normal.
Now imagine that the air flow gets colder. Real cold. The four tubes of hot water does dick to warm up the air. That 20 degree air comes out of the vents at maybe 40 degrees.
So you turn the fan to High. The faster the fan, the less time that air hangs around to be warmed and the more air bypasses the few hot tubes. But the water's still rushing through the heater core faster than it should and it's not giving up all its heat, so both hoses remain hot.
Pull out that dashboard. You need a new heater core.
On the genuine possibility that I'm wrong, here's Ford's troubleshooting pinpoint guide for insufficient heat in a 1st Generation Expedition. It's worth reading. The case illustrated was caused by a leaking intake manifold gasket.
https://www.justanswer.com/ford/2w7xg-ok-99-ford-expedition-no-heat-put-new-thermostat-new.html
Yupster Dog
Moderator
02 5.4 4x4 here and I am having the same problem. I am going to try the heater core flush. I have purchased 15' of 5/8 ID (inner diameter)that I will cut in half and a female garden hose end. (almost all should fit the 5/8 ID heater hose) and a quick shut-off for end of hose. I have a couple of buckets(and spring clamps if I need them) there are half a dozen videos about how to do this to our trucks. I plan on flushing the core back and fourth about a dozen times each. I believe like said in another thread this is just a temporary fix and I plan to replace the core in the warmer weather of summer if this works. will probably fit this job in my schedule within the next week or two. I will let you know how it worked out.
Yupster Dog
Moderator
I have done the flush and it was a great success. It went from 5% heat (you could only notice if the blower was off) to about 85% heat.(almost to the five minute high heat burn you out of the truck that we all know these trucks can do)
Not that hard to do once you figure out how to get hoses off. I removed 5.4 cover for better access.
the videos said to push the clips in while pushing then pull. file-1 (002).jpeg
so I saw the end of the hose and think the clips are in the holes at the end. WRONG They are not clips at all they are tabs that are at the very end of hose not in the hole. There are two tabs on each hose opposite each other. The drivers side hose the tabs are at 7 o'clock and 1 o'clock and the passenger side tabs are at 11 and 5. give the hose a little push towards the firewall and push the tabs towards the center of hose they will click. when you have both tabs pull hose off. Find and get O-rings either on heater core end or in the hose. two black and one hard plastic white. they go back on like a Oreo black white black, get this wrong and you will have a leak. when you go to put back the hoses it helps to have the hole orientated with the tabs at 1&7 and 5&11 your good when you hear the click. no click check your orientation.
The drivers side is the heater core input and the passenger is the output. so start with the passenger side. I tried without hose clamps first and it can be done but a pain and you need help because you are holding the hoses onto the heater core. so after I put clamps on I pulsed the water on and off to build pressure in the water hose. I did this for about 2 gallons and then switched sides and repeat. I did this 12 times on each side a lot came out at first then after 6 or 7 water was clear and very few pieces were coming out but every time all the way to the 12th time something came out.
Had I thought of it before hand I would have put a piece of plastic down over the engine to keep water and antifreeze off cylinders 3 and 4 but I did not and went for a hour and a 1/2 ride afterwards to evaporate any moisture that I could not clean up.
One more thing I learned was how easy it is to remove these hoses and how much space I have to work on cylinders 3 and 4. I wish I knew this when I put a Heli-coil on cylinder 3 it would have been so much easier.
dishgawd
Buckhorn, ON
great description Yupster.. I want to do the flush on my 2000 Eddie Bauer. Did you have to remove any cowling to make the access easier? Also I' wondering it it's safe to blow some CLR or facsimile into the core to help with the job instead of 12x water. thanks.. DG
Yupster Dog
Moderator
No cowling removal.
I personally would only run water thru. I don't know what would react funny to the antifreeze environment.
My core got stopped up after i changed my radiator. little black plastic pieces from the manufacturing of the radiator I suspect.
NOTE: That being said be carful how much pressure you use because if your core about to go or have a weak spot. (I had replaced the core about a year before so I knew it was ok for a little more pressure)
What I used,
About 15' of 5/8 ID heater hose (cut in half)
2 hose clamps
garden hose end fix (i got brass one and worked great in the heater hose without clamp)
Water hose (with the ability to shut water off at the end)
Bucket to catch what is coming out.
No draining necessary since the heater core is the high spot of the coolant system. (mind the hose that you pull you will get some spillage) I secured them strait up to minimize the spillage.
I tried to use a busted garden hose I had but water just went everywhere. so I got the 15' of heater hose so I could concentrate on the task at hand.
Clamped the heater hose to both sides of the heater core (didn't have to be super tight either) then just switched the water hose end back and forth on the other end. super easy
Now that I have done the flush it literally would take longer to just get the stuff together, pull out water hose and open the hood than to actually do it.
Trainmaster
Old School Member
Rockaway Beach, NY
Watch your pressure! These trucks have a bushing in one hose to reduce the pressure to the heater core. Like Yupster says, watch yer pressure.
Nothing will ruin your day worse than the sound of water trickling from the heater box onto your passenger side carpet.
