Heater Core Replacement
Eightiesrock80
Frankfort, IL
were can I find a guide to help remove the dash board on my 2003 nobody has any info on this nore does you tube. Everything I find is on 1st gen??????
Kawnbred
Hawaii
Changed mine about 3500 miles ago. Pin-sized hole. Used spectra brand purchased off rockauto : $30
2003 Eddie Bauer 5.4 also
When you remove the dash and gain access to heater core. You will stumble across the issue I have of inserting the fittings through the firewall; it will
simply not fit without disassembling the plastic housing which is virtually impossible.
FIX: cut the aluminum lines as I did and join via heater hose before reassembling the dash.
Disregard the markings I made on the heater core. I did that and took pictures in the event my Expi is stolen and I can identify via markings to Police.
-Fred
