rex450se
I am getting ready to upgrade the sound system in my truck and I'm going to start with sub's. I was looking at the Kicker CompR box with 2 12"s and the CX 1200.1. It's supposedly rated at 1200W rms and the subs are rated at 800W rms each. With this difference should I go with the box of 2 10"s that's rated at 600W rms each or will the 12"s be fine? I don't want them under powered too much, but the 12"s are in stock and I'd have to order the 10"s. What's everyone's luck with Kicker? I've had good luck with Kicker but it's been awhile since I've had them. Also, after doing the big 3 those of you that have added a system over 1000W, is adding a second battery a good idea or needed? Or do these all digital amps now handle power better than they used too? Is the 4Ga Kicker wiring kit going to be enough?
I know Kicker may not be the best out there but I can get an awesome deal through a buddy of mine. For the 2 12"s in the Kicker box, the Kicker CX 1200.1 amp and the Kicker wiring harness I can get for just under $500. After tax it was going to be $980 at Best Buy. So for $980 I could probably do better but being able to pick this up for under $500 am I going to be able to do much better than this? Thanks for the input
Victor
Here's what I'm looking at
Kicker 2 12" CompR's in a box
Same 2 CompR but 10"
Kicker 4Ga wiring kit
Victor
