obonaven
I saw this on another forum and I though would be cool to list anything about our Expeditions that are either hidden, cool, unknown, or otherwise not commonly known by all. There could be something in the owners manual that you found that most people may have skipped for instance. If you already know about it great but othr mays not know. Here are a few I've come across with the help of reading the owners manual or found on other forums. Mine of course are found on a 2012 EL XLT...
1. The truck has a simple alarm system. Lock your doors using the key fob with you inside. Wait at least 30 seconds then open the the door using the handle. The LCD on the dash will display a message - "To stop alarm start engine". It will be accompanied with a warning chime and will eventually sound the horn.
2. When you start the truck there is no need to keep the key turned while it cranks to start. You just need to turn it quickly one time and the engine will continue to crank.
3. If your lights are in the auto position the lights will turn on automatically when the wipers are turned on.
4. The little compartment on the inside of the center console lid is for tissues. Kleenex makes a special box that fits into the compartment.
5. There is a 2nd USB port on the SYNC module that can be used to attach a second USB device. It can be accessed only via voice using "USB2" as the voice command.
6. Items can be stored under the middle seat in the middle row, even when the seat is folded down.
7. Speaker Walk-Around Test. To enter the speaker walk-around test turn the stereo on and in radio tuner mode (AM/FM). To enter the speaker walk-around test, simultaneously press and hold the preset buttons 3 and 6 for a second or so then release. The speaker walk-around test applies sound to each speaker for about 1.5 seconds. Each speaker is tested and displayed on the audio unit in the following sequence: RF, LF, LR, RR.
8. Audio Unit Self-Diagnostic Mode. To enter the self-diagnostic mode enter the speaker walk around test. Then press the following preset buttons to enter the indicated test while in the speaker walk-around test. The audio unit self-diagnostic mode has 5 tests available. To exit the self-diagnostic mode, press the power button on the audio unit or turn the key to the OFF position.
• Preset Button 1 = Audio internal/external SELF TEST. This test is an on- demand self-test. If SELF FAIL is displayed, press TUNE > to scroll through the DTCs stored. Refer to the Audio Unit DTC Index. If the system is OK, SELF PASS will be displayed.
• Preset Button 2 = View/Clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the Audio Unit Diagnostic Trouble Code (DTC) Index (below). To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
• Preset Button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting. ** Perfect for testing antenna types and position changes. **
• Preset Button 4 = Software level query. This test queries each audio system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
• Preset Button 5 = DISPLAY TEST. This test will light all the audio unit display segments for 5 seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
Audio Unit DTC Index:
DTC - Description - Action
B1317 - Battery Voltage High - CHECK the charging system.
B1318 - Battery Voltage Low - CHECK the charging system.
B1342 - ECU Is Faulted - CLEAR the DTC. CARRY OUT the self-test. If DTC B1342 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility.
B2406 - Audio Disc CD Player Internal Fault - CLEAR the DTC. CARRY OUT the self-test. If DTC
B2406 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility.
B2477 - ECU Configuration Failure - CLEAR the DTC. CARRY OUT the self-test. If DTC B2477 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility. REFER to Section 415-01 . TEST the system for normal operation.
B2924 Audio Button Stuck INSPECT the audio unit for a stuck button and REPAIR the concern, if possible. CLEAR the DTC. CARRY OUT the self-test. If DTC B2924 is retrieved again, REMOVE the audio unit and SEND it to an authorized audio system repair facility.
B2965 - Audio System Speaker Circuit Fault - See Ford Factory Service Manual for troubleshooting steps.
