** KeyLess Entry Problem Please Help 97 Eddie Baurer **
ExpeditionLova
Lothian
Ok I Just Recently Got The Truck It Came With A Keyless Entry But It Didn't Work So I Thought It Was Just The Remote So I Got One Off Ebay & It Still Don't Work My Antenna Is All Screwed Up So My Radio Reception Is Horrible Im Preety Sure The Remotes Are Fine Just Trying To Locate The Problem Thanks For All Your Help !:smokin:
Exia
Kentucky
One quick way to tell is to put it into program mode to do this start with the key in the off position then cycle the key from off to run (not start all the way forward without cranking) 8 times in a row (on off) the door locks will cycle up and down if it has keyless entry (this is also how to program remotes some years you only had to cycle the key 5 times)..
If that dont work take it to a dealership so they can reset the remote and keypad on the door
