I had to have the right exhaust manifold replaced...it was a couple hundred bucks through ford (and they said to expect 3 hours worth of labor charges). When i dropped it off to have it replaced, they found an oil leak (which needed a new head gasket on the right side) and a new transmission dip stick tube (had a huge rusted hole in it). The exhaust leak i had was a little more expensive than most, cause what really happened: a bolt rusted and broke...the heat from the leak warped the exhaust manifold...when they were trying to take the head off, the busted bolt had to be drilled out...then they managed to break another one bad enough that they had to send it to a shop to have it drilled out. After all of that, parts and labor, it was just over $2000.00. My extended warranty covered everything but $60.00. The dealer submitted to my extended warranty that the manifold was warped and a broken bolt. They were able to sneak the transmission dip stick tube in as well.
