Leveling kits
offroadexpy
I've got the 3/2 on my 06', I removed the running boards cause it looks better. I went with the 295 75 17 terra graps, if Im not mistaken they measure 33 1/2 x 12 and I rub the sway bar at full lock to the right. So Im thinking the 35s would rub worse and probably would rub sheet metal somewhere, even tho the kit claims to clear 35s with stock backspace rims, so IDK... :shrug:
Spooky
I'm resurecting this thread because when I get back from my deployment, I'm getting a lift/leveling kit.
I've seen the kits on Ebay that are like these , but there are also Daystars and some other options. Which is better? I'm leaning towards the Ebay model because they're steel and should hold up pretty well.
The Daystars only come in a 2" lift and are poly. I'm eventually going with 34s so I'll need the 3/2 kit. The guy doing the installs said they usually go with the Daystars because the steel kits may be noisy. Has anyone has issues with the steel kits being noisy?
2000eb
on the old forum we had a few. and smooth had 33s on his after the 3/2 and it didnt look bad at all. and i could never fit in a garage. my baby was an outside baby from the start.
your garage doesnt count you live in socal the land of the prius
