This is just an FYI...
There are two areas that an ac compressor can fail - internally (pistons and bores) or the bearings in the housing. If the pistons are seizing small amounts of aluminum will enter the refrigerant. They will flow through the entire system lodging in the hose liners, evaporators, condenser and accumulator or receiver drier.
Most shops will flush the evap & condenser maybe even the hoses. You will not get all of it out. The repeated heat/cool cycles of use will cause the metal to release back into the refrigerant, taking out the new compressor somewhere down the road.
If you plan on replacing the compressor yourself, after the system has been recovered, inspect the orifice tube or txv for metal shavings. If it is clear, bearing seized and you are good to go, if not then total up all of the parts including hoses and make a decision on rolling the dice.
You should change the accumulator or receiver/drier every time you change compressors.
The worst part of this is having rear air....
I had a Ford Aerostar a few years back. AC had the black death & took out the entire ac system. The techs back then couldn't figure it out, changed part after part trying to keep it running.
