bridgerider
I have a 2018 Ford Expedition Platinum Max with less than 1,200 miles on it, first owner, purchased new.
Occasionally when I am driving, the entire digital instrument cluster will go blank, the entertainment/navigation screen will go blank and most of the vehicle's electronic controls will become inoperable (wipers, indicators, hazard lights, windows, sunroof, climate control, etc). The vehicle will keep driving and the headlights stay on (phew!)
My local dealer had it for three days but could not replicate the issue. Customer service at ford.com are no help either. Obviously the vehicle is unsafe to drive in this condition so I want to resolve this ASAP. This glitch has happened 6-8 times so far, usually within about 10 minutes of starting the vehicle, although once it happened upon ignition. In all cases, the electronics rebooted in 15-20 minutes and left behind the wrench icon, the check engine light and several other error messages. The power running boards are reset to Off when the electronics reboot, but everything else looks to be reset to defaults.
The first couple of times it happened it first threw a BLIS error before everything turned off, but in the latest instance the electronics were malfunctioning immediately upon ignition.
I do use a battery maintainer between drives as the vehicle does sit idle for a few days at a time, but my voltmeter has the battery right around 12V, so I do not think this is this issue (although I am open to suggestions). The dealer did not use a battery maintainer between drives. I have tried two separate battery maintainers that have been used on another vehicle with no issues.
I also have a dashcam installed, but it was in the vehicle while at the dealer, yet they could not replicate the problem.
It has happened in colder, wet weather (at least be CA standards) and in warm sunny weather. It has happened while driving on smooth highway asphalt and on crummy side roads. I cannot pinpoint any particular environmental conditions that have been present in each instance.
Help?!
Help?!
