My project has begun
Sierra Lima1470
Its interesting that with this Expedition, you are going a completely different route than you did with your first 3rd gen.
Its looking good!
daoud el-massri
ct
Nice truck welcome back . I have a eaton 112 on top of a 2001 5.4 that is all stock 11 lb of boost 440 wrhp 390 wrtrq 60 seeman injectors . Fuel 340 stealth Thank Tom 89 .
SOLISIMO
SOLISIMO
Ft. Lauderdale
Still waiting on the tune man. Jdm engineering says it's a complicated one...I guess cause the pro charger wasn't meant for this truck, I don't know
Mikes05expy
Toledo, Ohio
Is everything installed and ready to roll besides the tune?
Sent from my $amsung $III using Tapatalk
SOLISIMO
SOLISIMO
Ft. Lauderdale
You cant put on a new super charger, bigger injectors, different plugs without a custom tune. Its taking time bc its never been done before. As a matter of fact at first I went from needing to have 39lb injectors to now 47lb injectors. Other then that the rest of the car is pretty much done. I installed the rear carbon fiber wing and did the chrome piece on top of the plate also.
rayt
NY
out of curiosity, hows the hellwig working out? i have yet to install mine after a year
MattG
Toronto
Looks like this guy is long gone from the forum but was hopeful that someone may have some insight regarding the 23" saleen wheels.
I have a set currently being powdercoared bright silver and preparing to install on my '20.
Wheel studs for '20 are M14x1.5
The '08 F150 Saleen trucks were M14x2.0
Looks like 12/13 Expedition studs are also M14x2.0
My Saleen wheels are the original set with +44 offset in front and +30 offset on rear. 305 series tire.
I will learn the hard way to see if these will fit without modification but don't read any issue through this thread. Very limited info with this type of set up.
Anyone have any knowledge about the rears? The +30 offset has me unsure whether or not the studs will be long enough to give me thread to bite with my lugnuts.
Newport News, VA
the studs will be fine...i had 24s with +10mm so nothing will happen...offset deals with the wheel's backspacing pending on how the wheel is made...concave...deep dish...flat surface...
