Need Help on Replacing Brakes!!!!
chadr02
nashville
Guys, my brakes are making a grinding noise sometimes when you stop. I took the the expedition to the Firestong place because the tires needed rotating and the guy told me I was 90% wore all the way around. I bought the truck used with 23k on it and it now has 52k. Is this something I can replace and are there any writeups on how to replace the pads. I was quoted over 400 from the dealer and I have found another place that will put NAPA cermic on the from and rear for like 250.00 installed. Thanks!!!!!!
mustangrfast88
middletown oh
brakes are eazy to do you can do it yourself i mean that is if you have rear disc i mean but part should only cost you 100 if you are lucky i mean basic hand tools will do the job and should only take 3 hours at the most
mustangrfast88
middletown oh
yeah you might need rotors and have fun if you try to do it yourself. because if it is like a f-150 they are a pain to get the fonrt rotors off
C
chadr02
nashville
thanks, the rotors were fine and even the back had plenty padding left per the place I took it. They put semi-ceramic on it and inspected it for 151.00. I was happy. There is a big difference in the brakes now. I will probably replace the rear ones myself. Thanks for the help
smo0othride
San Diego, CA
Originally posted by lakmflx
If you were quoted 400.00 it is possible you may need rotors as well since you said your brakes are "grinding" I would take a tire off the front and check to make sure as well as the rear.
When I just took mine in today it cost $414 without new rotors. I did have the premium ceramic brakes put in though.
