No interior lights when doors open
bluefever98
Littleton,NH
I'm new to the forums. I own a 1998 Expedition. The interior lights do not come on when the doors are opened, neither do the running board lights work. The fuse is good. The bulbs are good atleast for the overhead one's, they work when pushed on. Has anyone had a similar problem?
Bedrck47
Elizebethtown, PA
The Courtesy Lamps Are inoperative
Fuse(s).
Circuit(s).
GEM.
Interior lamp relay.
Fuse junction panel.
GO to Pinpoint Test A .
The Courtesy Lamps Do Not Turn On With One Door Open
GEM.
Door open warning lamp switch (14018)
Circuit(s).
GO to Pinpoint Test B .
Bedrck47
Elizebethtown, PA
also check fuse #15 Its for the gem module but also part of the interior light circuits. Check to see if the interior lamp relay is installed and the Battery saver relay Both of them are in the circuit
Again use a meter to check fuses
Bedrck47
Elizebethtown, PA
They should be the two at the top of the inside fuse block
Do you have the owners manual if not you can download a copy at
owner.ford.com
B
bluefever98
Littleton,NH
The owners manual doesn't describe the relays as far as I can tell. The diagram shows two small ones at the top. I only have one of them.
Bedrck47
Elizebethtown, PA
see attached pic
If the top relay is missing that is the interior lamp relay Replace it and let me know the results
All 5 relays should be present
B
bluefever98
Littleton,NH
I just received the relay and installed it. For some reason when the driver side front door is open the interior lights flash like hazard lights. When any other door is open they just stay lit like they should be. Has anyone had a similar problem?
Bedrck47
Elizebethtown, PA
Most likely the drivers side door switch needs to be replaced That is most likely why the relay was removed
Bedrck47
Elizebethtown, PA
You may try spraying some silicon spray on the latch to see if it helps any.
And by all means leave your hammer in the tool box
B
bluefever98
Littleton,NH
I also noticed that the running board lights are not working, don't know if that would have something to do with it?
Bedrck47
Elizebethtown, PA
For the running board lights Check fuse #4 in the mini fuse block under the hood.
The door switch is located on the door latch
