Oops, Blower Not working
Dnny44
tuscaloosa
So, anyway to spare you all of the hilarious "details" had to pull the dashboard off of my 2004 xlt. I have done this before with out a problem but after I put it all back together and found that the blower wasn't working on any setting. I get heat but the blower is definitely not working now, from the front or Rear. Any suggestions would be greatly appreciated.
Bedrck47
Elizebethtown, PA
Appears that you did something wrong being it was working before you took it apart and doesn't work after you put it back together.
Have you checked to see if any fuse blew. If so how did you check the fuses and which fuses did you check.
Need to know the method you used to check them and the fuse numbers.
D
Dnny44
tuscaloosa
Got it fixed, I just forgot to reconnect one of the HVAC control connectors back to the control knobs, I just didn't realize the controls for the back also ran through those connectors
