My wife drives an 5.4l 07 Expedition with 100,000 miles. She told me the check engine light was on and it was running bad and that there was a fuel smell coming from the tail pipe. I brought it to a locale auto parts store and it was showing a miss fire on #3 cylinder. I changed the coil pack and the truck is running better we put a couple hundred miles and the light never cleared. I brought it back to check the code now it's showing a P0420.
I've been told that unused fuel is a big reason that a catalytic converter will go bad. I've also seen where the oxygen sensor could be the problem. My question is should I change the oxygen sensor if so which one should i change or should I change the catalytic converter? If it's the converter do i change the smaller or the bigger one.
