JollyRoger
2010 Limited (not EL), 170K miles. This has been going on for a while. I have a full understanding of the issue (slow leak on EVAP system test, like having a loose gas cap). I've cleaned/lubed/exercised the capless fuel filler 3 different times. I have inspected the wires to the canister solenoid, and the purge valve on top rear of the engine. I have not used a meter. I've looked for any tell-tale signs of cracked hoses on all associated components. My truck is in really good shape for it's age and mileage, with minimal rust or wear, especially underneath. I feel like my next step is to use a smoke generator to find any leaks. What I'd rather do is throw some parts at it...like a new purge valve, then a new canister solenoid. I don't mind spending the money on those two because they aren't that much.
I guess what I'm looking for is any pattern of this problem in 2010's or so, where anyone has replaced a part, hose, filler neck etc. Taking this to a dealer, even for diagnosis, is the last thing I'll do. Has anyone else with a similar year had this issue and what was the fix?
By the way, no impact on drivability or starting. Truck runs fine. After a week or so of pressing the reset button, it will finally light the CEL with P0442. I pull the battery for 20 min., then repeat the same cycle for a few weeks. I'd like to fix it, without a trip to the dealer.
Thanks for any ideas or input!
Bruce
Bruce
