Parking Break Adjustment Question
ExpeditionAndy
Fort Wayne, Indiana
Does anybody know if there is a procedure to adjusting the parking brake on a 2005 Expedition? Are they self-adjusting if I drive backwards and slam on the brakes?
I had it in to have the rear wheel bearings replaced a couple of months ago and they said that I had plenty of material on the shoes. They told me that the brake was working, but I cannot get it to hold on a hill.
I park on a driveway that has a hill and I don't like resting the weight of the vehicle on the parking pall in the transmission.
I'd appreciate any suggestions that you might have.
Hamfisted
Ft Lauderdale
You use a caliper and adjust the parking brake shoes to .018 clearance between the diameter of the parking brake drum and the shoes. That's the factory way.
-Mike
ExpeditionAndy
ExpeditionAndy
Fort Wayne, Indiana
You use a caliper and adjust the parking brake shoes to .018 clearance between the diameter of the parking brake drum and the shoes. That's the factory way. -Mike
Thanks Mike, my problem is I don't have a garage to work in so I'm hoping for a way that I can adjust them without removing the rotor.
Volk
Springfield, MI
Don't mean to hijack your thread, but did Bedrck47's info help? I have an 03 I got about two weeks ago and living in the Midwest, don't have a lot of hills. However, I was camping over the weekend and found a hill and my parking break did nothing.
Bedrck47
Elizebethtown, PA
Volk
Check on youtube for the following video
2002-2010 Ford Explorer Parking Brake Adjustment
although its for the explorer the expedition is the same
You should pull the rear rotors and check the lining's for the parking brake shoes and the brake surface on the rotors and replace if needed.
