I have an 05 expedition with 167k miles on it. A wk ago it start running really bad and even stalling. I replaced the fuel filter. It was really bad. After that got changed i could smell gas due to bad spark plugs. So i changed all the plugs. After the new plugs the truck ran great till after driving it for 15mins. Then it would run really rough and had a terrible idle while in gear. Shift it to park or neutral and everything would smooth out and run fine. Also, while in gear if i give it gas it would smooth out and run great again. I have no noticeable lost of power or anything. Well the check engine light cam on and gave 2 codes. Code 0022 and 0345. i replaced the driver side cam position sensor but it didnt fix the problem. So i dropped it off at a local shop.
Today they said the truck had low oil pressure and there was a knock. The knocking im assuming they hear is a diesel like sound that i get from time to time. It has done that since i bought the truck a year ago. Never had any problems til now though. I spoke with them real quick as they were leaving for the day. tomorrow im suppose to talk to them about possible solutions and cost to fix. He suggested that the low oil pressure is do to oil pump but i may need a new motor.
I know there is a very common problem with the cam phasers in this ver motor. Could this be my real problem and not motor or oil pump? I find it hard to believe that i would possible need a new motor when it runs so smooth when cold or while driving. theres no misfire, loss of power or anything wrong other then at idle and in gear after it warms up.
This all started after adding new oil. i used 5w20 castrol oil. oil fillter should probably be replace but i didnt do a full oil change only added oil because it was low. Also i hear using other oil filter other then motorcraft might cause issue and i know it isnt a motorcraft filter on it. But it has ran fine till now. i am due for a new oil change though.
Im at a total loss as to what to think or due atm. Could flushing motor help? Any and all is much appreciated.
