Rear Differental Fluid Spec - 2024 Expedition Timberline
Jozef Zoldos
Phoenix
Hello All
Looking for the correct answer. I have a 2024 Expy Timberline with 30,000 miles. Looking to do fluid change on front and rear differentals and transfer case. The specific question that I have is about the rear differental which is an eLSD in my trim.
I purchased 75W85 gear lube for the rear differental. I am getting conflicting information on the internet about whether or not I need to add 4 oz of friction modifier. Gemini AI says that I do not need to add friction modifier because it is a "Control Trac eLSD that utilized an electro-hydraulic pump to engage the internal clutches unlike the traditional mechanical limited-slip differentals". Gemini goes further to state that if I add a friction modifier, it could result in clutch slippage, reduced capability, and computer confusion leading to error messages. The Service Manager in my local Ford Dealership, however, told me that I need to add it.
What is the correct answer?
Thanks in advance....
Joe
Grrumpy
Navy Law Enforcement
On-line 2024 Expedition Owners Manual specifies rear with limited slip requires friction modifier....4 ounces.
Also, 75-85 gear fluid needs to be full synthetic.
DieselMonk
Atlantic Canada
just what Grrumpy already said. You forgot to mention it will increase heat too without the friction modifier.
Grrumpy
Also......ask yourself.....what does an AI know about vehicle maintaince ??? Does it own or drive a vehicle ????? Does it service a vehicle ????
Will it reimburse you if you follow it's advice and that advice causes damage....your rear end grenading ????:rotflmao:
