rear hatch window question
mnerat
m
So the glass on the rear door is loose. The little plug on the inside of the window has come undone from the part it is attached to on the outside. Can I just glue them together or do I need to have a new plug or anything? I live in Michigan so not sure how well glue will dry and seal in the cold
M
mnerat
m
After looking at it closer it's actually a screw. It was stripped and fell out/broke . White aluminum?? Why use it?? Anyways I took the plastic washer off, drilled out and retapped the hinge with a 1/4 28 and used a bolt and some window sealer to get it back tight. Should work good. Better than wasting $50/$75 on a new hinge
M
mnerat
m
The threads were worn out on both the screw and hinge
