Regular or Premium
montecarlo31
Google would have all of the proof you need. Higher octane is designed to allow for higher compression motors to run without early detonation. If you increase octane without increasing compression, no more power is made. Stick with 87.
Sent from the Pocket Computer
Not quite but thanks for playing. There is more to the equation then simply "compression" and google. If the engine can make more power on E85, which it does, it WILL make more power on 93, 95 etc. Remember these engines has the ability to adjust timing on the fly which is where the increased power comes from when running E85. There is no change in compression as you imply.
FordandPolaris
Saint Cloud, MN
Just because the octane fuel changes doesn't mean the motor will automatically change it's timing. The only time it changes timing is if it detects knock, and then it will retard instead of advance. The timing is set somewhere around 10 degrees advance to meet fuel efficiency and smog regulations. It will not go more unless you upload a custom tune that tells it to do so. This is why Edge and SCT programmers make such a big difference.
If you believe that, run premium all you want. I run it in my sleds due to them running a high 11:1 compression. My truck runs 9:1 so there is no benefit to running premium. E85 equates to 105 octane (race fuel) but the only time you need to run race fuel is when you have race compression (11:1 or higher). Otherwise it's just a cheaper option to 87 pump gasoline.
metaldrgn
somewhere
Actually that's pretty much the entirety of octane ratings. How much they can compress before they autoignite. Of course the rating is the rms value of RON and MON combined. For regular gasoline generally the higher the rating, the slower the burn rate which is why it's usually better to stick with the lowest rating you can run. With a variable cam you can change the dynamic compression ratio which is pretty much the only reason you could see a performance boost from using a higher octane. E85 is a different animal since it uses ethanol. Ethanol can make more power because it has oxygen in the molecular chain but you have reduced fuel efficiency because of that and the fact that the molecular chain isn't as long as gasoline I believe.
You are right in the respect that it's more than the static compression rating.
montecarlo31
If you are only getting 10* then something is wrong. I am getting more than that on a stock tune.
metaldrgn
somewhere
The baseline is set around 6 degrees and it advances more with rpm and load up to around 50 degrees depending on the engine and tune
01yellerCobra
San Diego
That also depends on the load. 50 degrees of timing at high rpm and high load is a little much.
expydude
va
Why are some of you guys only getting 6 or 7 mpg with a 3rd gen? I haven't had that bad of milage since I had an 84 bronco with a 351 in it
Sent from my SAMSUNG-SM-G900A using Tapatalk
01yellerCobra
San Diego
I think I may have found the reason for mine. Or at least a symptom. Over the last couple of weeks I've noticed a tapping sound. Started off barely audible. Thought it was just me. Now I can hear it sitting at a light and the truck is down on power. Back to the dealer she goes. I've seriously been considering trading it in. The warranty is almost up and I'm worried about future issues.
k9education
Regular. I tend to avoid cars that require anything more. I would make an exception if I could afford to get this beast up near 500hp though.
46L281GT
KY
Unless you have your vehicle tuned for premium or have a vehicle that requires premium, there is no point in it. I use regular in the expedition and my wife's saturn sky. Until recently i used regular in the mustang. premium never made a difference. Now it is tuned for premium so i run it because i have to.
juan214
Stoughton, MA.
Regular fuel all the time
I watched a youtube video about this last month. The fuel type makes no difference to the cars computer. Higher grades you pay for the research and development of all the fuel types. Higher are not better than lower grades and the research showed the emissions were worse with the higher grade fuels.
