just wondering, what would it do to the engine if its leaded?
Leaded gas will kill your cats and O2 sensors over time. Leaded gas went away due to environmental reasons. If you look at the label of some of those octane boosters, which have lead in them, they will tell you extensive use of the product will lead to O2 sensor and cat failure.
Personally, I think running any more octane than what the engine is tuned for is a waste. All engines in modern cars, whether it is a high end sports car, or an economical car are built and tuned to very tight tolerances for a specific type of gas. This is because manufacturers want to get every ounce of efficiency out of the engine when it comes to gas mileage. This is also why tunes for pretty much any modern car, even high performance sports cars, will sacrifice a bit of performance for better gas mileage.
So will an engine technically perform better with higher octane fuel than what it was originally tuned for? Sure it will. But will the engine perform at max efficiency with higher octane fuel without a tune for it? No.
