Remove Rear Quarter Glass
RogerD
Florida
To remove the rear quarter glass (07 exp). Do you just remove the window frame nuts and pry the frame away from the body? I would prefer not to break the glass in the process.
I came across this video on YT of an excursion and it looks basically the same as an expedition. https://www.youtube.com/watch?v=jEOx3UnpTXA
Trainmaster
Old School Member
Rockaway Beach, NY
The video erroneously says the window is installed with "silicone". I believe a urethane adhesive like 3M 08693 must be used. Check a shop manual. It would cover the materials needed.
There are also tricks to cutting out the adhesive, like using a piece of piano wire to part the glass from the frame. The video's method of prying against the glass with a metal tool appears barbaric.
