Replacing or Repainting Grill '01 Exp. EB
nobycane74
SW FL
Hello Expedition Guru's. First real post in braining storming a new project for my 2001 Ford Expedition EB.
As with a lot of the Expedition's, the front grill has faded and looks terrible.
I honestly considered repainting it after years of fighting the task of using 'back-to-black' solution to keep it looking decent...but ultimately have lost that battle.
But considering this is a 2001, with 108k miles on it, (i am the original owner) and looking to keep it awhile and wanting to keep it viable, running good and just upgrade some options on it, I have considered replacing the front grill. Not with an OEM replacement - but with a "honeycomb" style, that was available on the same year F150's.
Now, I really like the honeycomb style, it gives it a cleaner look and more of an updated look too.
Here is my dilemma, I can easily purchase a whole new grill assembly as pictured above, but I would have to endure in painting the trim around it to match my truck (Estate Green), which could cost me a couple hundred bucks (not too interested in that route).
I am wondering, it is possible to actually remove the grill itself on both the new part and the OEM part assemblies, and just swap them out individually?
Would that be a pain in the neck? Or more of a wiser decision?
Thoughts, comments, suggestions all welcome.
Thanks in advance.
Tank_Snake
San Diego
If I'm not mistaking the actual grill portion just pops on with clips.
I figured this because mine is slightly "aged" and it pops in an out
Sent from my SAMSUNG-SM-G935A using Tapatalk
dschallmo98expo
FL
here is aftermarket attached to mine. The original grill is not held In with fasteners. Looks to be glued or pressed in. IMG_1989.JPG
Adieu
SoCal
Take off.
Tape off the parts you dont want painted.
Spray with paint or plastidip of choice.
nobycane74
nobycane74
SW FL
UPDATE:
I was able to locate a 2001 Ford F-150 grill insert in excellent condition at a scrap yard in central Ohio, I had my father go and investigation it to actually see the condition...it worked out and appeared to be in excellent condition, guy wanted $25. Bought it, and my parents, since they are coming down to visit me in Florida here soon...they are going to bring it down with them. So far - so good.
nobycane74
nobycane74
SW FL
UPDATE #2.
Spent some time this week repainting the new grill replacement... that will endure a newer/fresher look on the Expedition.
houlster
AZ
So does it actually fit? I wanted to do the same thing but everything I found online said the inserts were a different size between the F150 / Expedition & you had to swap the whole front / headlight surround piece. They sure look the same though.
--Dan
nobycane74
nobycane74
SW FL
--Dan
I will begin working on this replacement install this weekend... everything I have seen, read and physically compared indicates they are identical in size, and the fastening clips are identical too.
So stayed tuned...and I will report (with success hopefully), and post finalized pics.
[keeping fingers crossed] :party52:
nobycane74
nobycane74
SW FL
UPDATE #3.
EPIC FAILURE.
Come to discover that the new honeycomb grille is doesn't fit. It is about 0.5" short on both sides. The tops and bottom clips align perfectly...however, it is too short on either end.
It was almost impossible to ascertain how that occurred. The initial explanation is that the grille is truly not from a 2001 Ford F-150 and the scrap yard attendant did not know his ass from a hole in ground and had them mislabeled.
I looked up the part number on the grille insert, it indicated it was from a 2003-2004 F-150.
So I am at a loss right now...have the whole grille assembly and lights out and now I am beginning to repaint the original OEM grille and put it back all together. Ad chalk it up as a $20.00 loss for the part, and 2 days pulling the assembly and lights out.
I am not sure I am trusting the aspect of buying a replacement aftermarket grille/assembly that is honeycomb and pull out that specific insert and install into mine, because I fear the notion that it will not technically be the same size dimensions.
I had a grill insert I was trying to sell for a friend about a month back, and noticed it was totally different from a 97. It was closer for my 2000, but wouldn't fit mine either. The grills and inserts change almost yearly on vehicles, manufacturers do that to keep New Years fresh and different, without major expense. That's been going on for years.
z168
Cali
There have been many discussions on grill swaps. the F150 grill is narrower on the bottom compared to the Expes. If you want to use an F150 you have to use the whole grille frame assembly. Good news is the aftermarket option is not too expensive
