Could you explain what happened here?
Yup he had the diodes pointing the wrong direction in the housing. Simple fix if he had read the instructionsCould you explain what happened here?
Yes they should be at the 3 and 9 o clock position. I’m trying to find a video DD put out about adjust themI just installed the DD SL1 and have this same issue. What do I need to do? I read the instructions. Do I need to make sure the diode is adjusted to completely vertical? I didn't check that before install. Why would they be angled by default?
