Securicode
ssurles268
Tennessee
So just bought 16. Went to set a personal code. Tried on door no go. Went through Sync 3 and said original code was wrong. Doubled checked code, even took off kick panel to confirm. It is like the code is wrong.
Anyone ran into this. Auto start and other features work.
East-TN
Air Force
TN
No. I just bought a 17, took off the passenger kick panel and noted the original code...made my personal code with no problems.
J Ski
3.5plati
VA
You did:
Enter factory code
Press 1 and 2 simultaneously
Enter new 5 digit code
Doors will lock and unlock
AllBoostNoEco
GA
I have SYNC 2, but when I first went to enter my own code, I somehow accidentally wiped out both my code and the factory code. At that point even the factory code became useless. I didn’t think you could delete the original code, but it sure wouldn’t work for me.
I had forgotten about it until I started playing around with FORScan, and I’m only guessing, but reprogramming the APIM apparently reset the code and I was able to use it from that point forward. Not sure if SYNC 3 works the same, but maybe someone deleted the factory code? Perhaps a hard reset of your SYNC is all it will take to restore it.
East-TN
Air Force
TN
If you have Forscan you can read the code and make sure you are using the right master code. Or, if you are near Knoxville I can help you.
East-TN
Air Force
TN
Sounds to me like he does know the original code but it isn't working
Look at his first post...maybe I should say he doesn’t know the correct factory code. Or his Expy isn’t recognizing the code.
