should i weld...
panda24619
San Diego
the rear spiders? good or bad idea? ive seen a few that work out great on the street, but have herd storys on when the welds brake. should i take it in to a good shop like orw and have them do it for me or something?
99 Expy
Laramie, WY
I wouldn't weld it. The welds can break, or the diff could give too, then your rear end is shot. When welding the gears, you lose your differential and have posi. When you go around corners, your wheels will spin at the same speed no matter what, and this will also eat up your tires. It would be ok if it was an all off road rig, but with lots of highway miles, you wouldn't like it.
panda24619
panda24619
San Diego
thats what i figured. o well. ill just save up for a detroit and do a whole rebuild on the axle. new bearings and axle shafts.
99 Expy
Laramie, WY
I'm planning on going with a detroit sometime, but that will be after an engine rebuild and 9.75 rear end.
panda24619
panda24619
San Diego
why get the 9.75 if your gonna upgrade? do the 9" or go with a d60. more options and what not.
Canadian Expy
Toronto ON
Don't weld for street use ...I had a Detroit in my last Daily Driver ..fun in the winter but it worked :flamingdevil:
FtLaudBlkGT
I would not recommend welding them, as you take a turn, the inner wheel will want to spin as fast as the outer and with big tires, it's going to be a big mess if the weld doesn't hold...
walnuts4x4
Watertown, NY
yup dont weld... cheap alternative is find a rear end with the factory limited slip and swap them out.... or save up for a real locker... my old 97 f150 had a detriot lock-right with 4.88s in the 8.8 rear turning the 38x15.5s all with the 4.6...
panda24619
panda24619
San Diego
i just thought i would put it here. naw i wont weld them. hmmm... a lsd. why didnt i think about swapping them before? i need to go to a junk yard now. i bet i can get one fairly cheap.
toms89
technical advisor
MD
I would never weld the spiders which is basically a poor mans spool just for safety reasons alone with a street driven vehicle. Would make handling a nightmare and near impossible in the rain. It would always tend to oversteer as you are forcing the inside wheel to spin. On dry pavement eventually an axle or the differential would break as this puts tremendous stress on them.
By the way the factory limited slip thats in mine is very tight and performs very well. It is constantly trying to scrub...or spin the inside wheel while turning. I think you would be happy if you can locate one.
panda24619
panda24619
San Diego
good idea. ill try and find one. at least until i can afford a detroit.
2000eb
i am very happy with my rear lsd it performs outstanding im really rough on my poor expy. now if only i can get one for the front ill be set
