97_edition
To the OP, yours sounds like a low grade misfire. I would look at the plugs and coil packs.
To the guy with the 97, I would think that this one is more related to an electrical issue too from what you described. The MLPS (neutral safety switch) comes to mind first and the TPS (throttle position sensor) comes up second. I don't see how fluid issues would be causing what you described. But, stranger things have happened and, of course, I might be misreading what you are trying to describe.
Darrin
Thanks for the thoughts. I am having the tranny flushed so I will see if this takes care of the shifting issue. (This needs done anyways).
Also while talking to the mechanic, with servicing the transmission he told me I will not need to replace the transmission filter. I asked him why and he explained that there is a one way valve that allows the "dirty" transmission fluid in but not out (the filter traps dirt). With the "machine" hooked up it allows for the valve to be opened, which then allows the filter to be "cleaned", all dirt is flushed out of entire transmission including the filter. Has anyone ever heard of this?
