Storing Second Set of Wheels + Tires
Shotgun76
Suburban Chicago
Any suggestions for storing a second set of tires (mounted) and wheels? Most likely will need to store outside behind my garage due to space considerations. First set are my 22" stock set and second are stock 18" takeoffs from a '25 Tremor Expedition. Thanks.
Fastcar
Army
FL
Air them up to the max air pressure. Can you fab or buy some bracket's to hang them off the back of the garage?
GixxerJasen
DFW TX
It's amazing how much space they take up, even stacked four high. I was so happy to sell my stock 22's with tires and get them out of my garage.
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Storing tires (or any other rubber items) outside is a recipe for disaster, at least in terms of longevity, unless they are vacuum-packed, sealed air tight, and protected from direct sunlight & wide temperature changes....
And these things really won't do your rims any favors either....
But the #1 thing to do first: thoroughly clean & dry them for at least 24-48 hrs before storing them !
When I had to store a set of tires w/rims in my shed from another vehicle, I wrapped them in some very heavy black plastic sheeting (I believe it was 16mil thickness, which is the equivalent of about 5-6 really heavy duty commercial trash bags in one layer), pulled together at one end to make a long twisted "handle", injected some silicone caulking into the twisted part, then twisted them even tighter & secured them with very several heavy-duty black zip ties. Then I wrapped them with a 2nd piece of the black sheeting and duct taped the crap out of it....
And 1.5 years later when I sold them, they were still like brand new and had the same 36psi of air in them :D
I feel like this would have probably worked even if they were stored outdoors, but I had the room in my shed & didn't want to take a chance on ruining them...
bb37
Member Relations Specialist
Indiana
Sunlight is hard on the rubber compounds used in tires. Keep them covered if stored outside.
Ozone is also hard on the rubber compounds used in tires. Keep them away from large motors or other electrical devices that might generate ozone.
Shotgun76
Shotgun76
Suburban Chicago
Appreciate the responses; planned on bagging them individually and tarping over the stack to keep them out of direct sunlight. The 18" will be for winter/off pavement use (do some hunting in SD and winter sports up in the U.P. of MI, both locations are a bit of " back of beyond" dirt and gravel two tracks. The 22" look great and are o.k. on pavement but harsh for anything else.
