Happy Friday all. I'm glad the weekend is here and it's time to break out the wrenches.
I've got a metal grinding noise in the suspension only when the steering wheel is turned pretty far (but not locked) and it's worse when coming out of the driveway at an angle. After looking, I found the boot on the upper control arm ball joint (drivers) is bad. However, I cannot find slop in the ball joint when prying on it or using my feet to kick. Nor did I notice slop in other components when prying or using the wheel to pry on the suspension while it was lifted.
I cleaned the boots and added grease to the control arm and outer tie rod ball joints via a grease needle, they may or may not be original suspension parts at 206k miles. The noise remains but I've only driven a couple miles so far. I assume the control arm should be replaced, but how do I better verify that the control arm is bad since I wasn't convinced after pry and concussion tests?
Pictures of the control arm ball joint boot with wheel locked to each side.
