Rockunlimited2
The power third row seating switch found inside the drivers side rear door on the drivers side rear interior trim panel behind the second row seating that controls the power third row searting is not working. The switches for the same function that are found near the tailgate work fine. Is this a switch issue or is it a seperate fuse/relay? I see that fuse 104 is for the LH switch, but it is also for the LH motor, does that mean if it was tripped, the RH seat would not go up with the LH seat? Both sides work with the rear switches.
