Rcalvin
Can my 2017 Expy with 3.5l dual turbo and HD tow pkg tow a 5800lb Grand Design 2600RB? Dealer says no problem.
What is the tow capacity for the HD Towing? I have 2017 Expedition XL EL EcoBoost and it has the Factory Brake Controller and both 4 & 7 pin connectors
I tow a 2018 Jayco JayFlight 267BHWS (5,660lbs dry and around 6740lbs loaded up with full water tank). 2017 Expedition tows it fine but watch your engine and transmission temps on any big climbs. Also, make sure you have a quality WD hitch.
I just looked at this exact trailer this weekend! Need an upgrade from my current one (Forest River 26DJSE). Do you have the tow pkg on your expy?
The jayco is about 1000# heavier than mine which has me a bit leery without the HD tow pkg.
I’m looking into the transmission cooler upgrade regardless. Tranny was running hot on our last trip, and it was all flat.
I added the aux transmission cooler myself following tips from people on this forum. Must have for heavier towing with the Expedition.
Page 24 of the 2011 Ford Towing Guide shows a 6000 pound maximum towing capacity without the HD Tow Option #536.
Your truck lacks any means to connect to the required trailer brakes -- the 4-pole connector is for UHauls and boat trailers, you need the round 7-pole connector which is on the right side of the hitch receiver.
Page 17 shows what you need. All parts are available at your local auto parts recycle shop (AKA junk yard).
-- Chuck
