ExpeditionAndy
The V8 makes 310 horsepower with 365 lb/ft of torque. It can tow an impressive 9,200 pounds. (I actually didn't know that, I thought that my Expy could only tow like 6,000. Great to learn!) Meanwhile, the Ecoboost V6 has 365 horsepower, and can make 420 lb/ft of torque, but it can only tow a dismal 6,600 pounds.
The 17 can tow 9100 LBS on the 4X4
Turbos run cooler than catalytic converters, you are more likely to set a fire with one of those than with a turbo. Ford's recommended service interval for normal duty is 10,000 miles and 7,500 heavy duty service.How about the V6 though? It does have two turbochargers, which definitely gives it some pep and some fuel economy, but turbochargers are not as reliable as a solid, mechanical V8. I had some trouble finding other problems, but I found a few. For starters, the turbos tend to get extremely hot, which could be a fire hazard if you happen to find yourself driving through dry brush, or if they are near any wood. Also, since it's turbocharged, the oil is heavily used. If you forget to do your routine oil changes
The EB engines use timing chains just like the 5.4 and based on your own research they produce 55 more horse power, and 55 more ft/lbs of torque. And there are EB engines out there with well over 150,000 miles on them and have been in F150s since 2011....then the timing belt could have problems. However, I do not think that the Ecoboost is a bad choice. Ford is selling them in their F150s like hotcakes, and they seem to be like reliable engines (though they are not as powerful, no matter how much Ford wants you believe they are).
As I tell my students, its nice to see references. Unfortunately I see some conformation bias in your selections. The last article is from at least 2011 or 2012 and talks primarily about software updates and early timing chain issues which were corrected long ago. I would put the EB up against the 5.4 and say it will out perform the 5.4 in any test, and I would love to see somebody do a test.Sources:
http://www.ford.com/services/assets/Brochure?make=Ford&model=Expedition&year=2013&postalCode=90210
https://jalopnik.com/these-are-the-cars-that-people-keep-the-longest-1795160276
http://jalopnik.com/these-are-the-cars-that-are-most-likely-to-go-over-200-1793819071
https://www.knowyourparts.com/technical-resources/engine/common-issues-3-5l-ecoboost/
I'm done.
