Pugnowski
Hey all,
was wondering if someone else has ever had this problem? Have a 2000 Ford Expy with a 5.4 in it that I swapped in 1 1/2 ago.
Thought my oil pan gasket was leaking, as it was dripping all over. Went through procedure to remove axle support and took pan off.
Problem is, I can't seem to get the axle support bolt holes on left to line up? Anyone else have this problem?
Tried several things but no luck..I am thinking I may need to loosely bolt up the crossmember first, and then the other axle supports in front, but is not how service manual describes it..see attached....
thanks in advance...
