If what your saying is true, the SCT x4 tune, tells the PCM to ignore the knock sensor(and maybe red line?). Racers know, running your timing, too far advanced will shorten engine life. That is why they use race fuel(100+ octane) Running it constantly retarded(like a stock EB on 87), will not completely burn fuel and produce carbon. Look at the tailpipe of a vehicle with one. Its all carbon. The stock EB 3.5l should burn 91 or higher, all the time. The fuel saving myth of engine is exposed with some clever wording in the manual. The older fox body 5.0l Mustangs, all ran better with a manual distributor, timing tweak and air silencer removal. About 4 degrees was the max. The catch was you always had to use premium. On a newer vehicle, a mild 'tune' is best, but your also using premium all the time. There is no way around it.
