Under hood accessory power
Kevin08
Illinois
Is there a place in the under hood fuse box to add a 10awg output? I’m about to install an electric scooter lift in the back of my 2008 Expedition. It will ground to the body at the rear, but I’ve bought a 10awg power line to run from the battery to the rear. I’ve read online that these lifts can parasitic draw and I should use the main off switch. But I thought I might use a relay that takes its trigger from the delayed accessory circuit, so when I unlock the doors, the lift will have power again.
I can’t add a fused wire right onto the positive battery cable, but I’d rather have it in the under hood fuse box if possible.
os1kne
Atlanta
This is a great question. I'm tagging so I can see responses easier. I haven't tried / needed to do anything like you're suggesting on a vehicle newer than ~ 1995, so I don't want to give you an answer that would screw up the factory computer, etc.
Langer
Chicago
do you have the 7-prong trailer electric on the back?
Kevin08
Kevin08
Illinois
That was supposed to read CAN add, not can’t. Edit function has already been taken away.
Kevin08
Kevin08
Illinois
Only the 4 wire is visible by the receiver. I haven’t checked to see what trailer wiring is back there. Is the +12V in the 7 constant or switched with ignition? I’d need constant
Langer
Chicago
good point, it’s not always live.
Glen B Ashcroft
USA - Oklahoma
yes on the fuse block in the front under the hood i found an empty fuse spot on the left side on the block, i mean drivers side
i inserted a male connector then fused it
i used it to run the daytime running lights on my new head lights
lbv150
Northeast
Fuse it at the battery + post and if worried about a parasitic draw use a relay. I add accessories to vehicles all the time this way in our business and you are correct to ground it to the chassis. I have corrected many installs where the ground went back to the battery - post.
Kevin08
Kevin08
Illinois
Thanks guys!!
I’m going to use a relay triggered by the accessory reserve circuit or battery saver or what ever it’s call that kills power about 30 minutes or so after the key is turned off.
lbv150
Northeast
Thanks guys!!
Perfect!!
No members online now.
rockinghranch
