Silly question but can you power wash under the hood
MikeN
Calgary, Alberta
AS the header says,
under my hood my motor is dirty as hell with dust from the dirt roads near my house, can I power wash the shit out of this? or will this cause issues?
BigOleFordFan
Zoom Zoom goes da "Tang" !
Army
Yes you can, as long as you are careful about not using high pressure around any electrical connections/wiring harnesses..
Just make sure the engine is cold, and focus the spray on the grungy area only, like the engine block, exhaust headers etc...
I do this about every 10K miles or so (on all 5 vehicles) nottaproblemo, keeps 'em lookin real goooood !
Savannah Dan
Savannah, GA
I don't use anything stronger than the garden hose with spray On a cold engine, I spray the whole area with Dow scrubbing bubbles, wait 10 minutes, spray down again, wait a few minutes then spray off with the hose. Engine stays looking new with 150k plus miles.
Billme
Hattiesburg,Ms
I use Chrisfix method on YouTube
limeybiker
Ocala Florida
Back in the UK I always used a product called GUNK, never use a pressure washer garden hose is sufficient, motorcycles and cars.
rollinstone
Seattle
I use a pressure washer, but I don’t place the high pressure nozzle directly on any specific component. I rather hold it back a little so I’m getting mostly a lighter spray effect. Hard-to-remove stuff I’ll hit it with high pressure making sure I’m not compromising sensitive components. The cleaning products mentioned above help.
Woodwolf
MI & ON
My oddball approach is spray/soak the engine bay 2/year generously with W40 and let sit for a refreshment or two. I then use a mild degreaser to soak the engine for another refreshment and pressure wash (cold!) engine with medium hot water pressure. Works for me since years and my engine bays look slicker than a monkeys' east end running west
BlackBetty
Army
Surprise, AZ
I use Turtle Wax Tire Cleaner/ Shine. Spray it on. Let it sit to break down gunk for about 5min, or so. Then use compressed air to blow off dirt/ grime and excess Turtle Wax product. Leaves a low clean sheen on the engine bay components.
No chance of getting water on anything using this method.
