If done correctly I'm sure it'll look pretty good but I just don't have the patience for vinyl after some failed attempts of wrapping things in the past. Make sure you come back with pics!Anyone tried wrapping the edges of their tail lights like the 17 escapes? Think it would look pretty sharp. Gonna give it a go sometime this weekView attachment 23877
I tried some vinyl I had laying around the house. It will look great but following the curve is a PITA. probably going to tape it off, scuff it up, and paint it gloss black.If done correctly I'm sure it'll look pretty good but I just don't have the patience for vinyl after some failed attempts of wrapping things in the past. Make sure you come back with pics!
Maybe get some transparent paper and trace the area you want to wrap. Then cut it out and you have a template to use. Flip it over for the other side. I'm sure it'll be much easier to cut on a flat surfaceI tried some vinyl I had laying around the house. It will look great but following the curve is a PITA. probably going to tape it off, scuff it up, and paint it gloss black.
