David Pedron
hi all,
thanks in advance for your help!
I have a 2003 5.4 4WD, It recently started making a weird noise which sounds like its coming from the front drivers side but I could possibly be wrong about that.
The noise happens primarily in 2wd. when I put it in 4wd the noise is much less noticeable and is not as consistent but still there, slightly. I had two different mechanics tell me the hubs needed to be changed so I changed them myself. The install went fine, no issues there, but the noise was still there when I took it out for a test drive. the noise is loudest when I press the gas and when I let go, something kinda bangs under the truck, the noise stops for a moment, and then starts again a few minutes later.
I've attached a video here , I'm hoping someone else has experienced this. I cant seem to figure out what is causing this noise.
I appreciate any input,
Thanks
Thanks
