TheRoosterMMA
04 expedition xls.
Passenger front power window stopped working. I pulled the door panel... motor is fine. Neither window switch will work (passenger side or driver switch) All 3 other windows operate fine from driver panel and the ones in their doors. It is only the front passenger that will not work. I replaced the driver master switch panel. No luck. I did not bother to check the fuses since the fuse(s) involved feed all 4 windows.
I thought I read some where that if the passenger side window switch is bad, the driver master switch will not work either. Any truth to this? If not I am stumped. Advice / experiences related all appreciated.
thanks
thanks
